Odd Power steering issue
I had my steering box replaced a few weeks back and everything has been fine. Yesterday I drove in and out of Vancouver about 4 hours mix of highway and regular streets with a few stops.
Near home turning a near stop the steer got very stiff, no issues at speed. A little later making a left same thing.
Got home check the fluid level and for motion in the tank seems fine and the fluid is clear. Took a short drive no issues steering worked as expected.
Check for leaks none found there is some dye in the fluid, I did find one tire rod end leaking grease so I greased that.
My suspicion is the pump, assuming it is the pump is replacing the lines recommended ?
Are there any good tests to check the pump ?
Is a full fluid flush worth doing as a diagnostic ?
Final update for now
, the problem has not re-occurred. Another long 100 miles and no issues I will update this thread if there is a re-occurance.
Thanks for all the suggestions I will be going over them in spring
, the problem has not re-occurred. Another long 100 miles and no issues I will update this thread if there is a re-occurance.Thanks for all the suggestions I will be going over them in spring
