Odd Power steering issue
Old Dec 8, 2023 | 12:07 PM
Richard Gallant's Avatar
Default Odd Power steering issue
I had my steering box replaced a few weeks back and everything has been fine. Yesterday I drove in and out of Vancouver about 4 hours mix of highway and regular streets with a few stops.
Near home turning a near stop the steer got very stiff, no issues at speed. A little later making a left same thing.
Got home check the fluid level and for motion in the tank seems fine and the fluid is clear. Took a short drive no issues steering worked as expected.
Check for leaks none found there is some dye in the fluid, I did find one tire rod end leaking grease so I greased that.
My suspicion is the pump, assuming it is the pump is replacing the lines recommended ?
Are there any good tests to check the pump ?
Is a full fluid flush worth doing as a diagnostic ?
Old Dec 8, 2023 | 01:35 PM
Smalll update did a lock to 3 or 4 times got a couple of bubbles out - flow seems strong - no issues with the wheel.
Old Dec 8, 2023 | 08:50 PM
JohnZo's Avatar
I wonder if the idle speed dropped very low when the problem happened.
Old Dec 8, 2023 | 11:39 PM
@JohnZo It was odd no problems tonight either, it could be an aging pump or hoses or just the universe having a whacky sense of humor.
Old Dec 10, 2023 | 07:48 AM
CollieRover's Avatar
Check the condition of your steering column. My bearings gave me this issue for years, and finally seized up.
Old Dec 10, 2023 | 12:57 PM
Final update for now , the problem has not re-occurred. Another long 100 miles and no issues I will update this thread if there is a re-occurance.
Thanks for all the suggestions I will be going over them in spring
tnkeith
May 20, 2018 03:52 PM
B-Man77
Jan 22, 2013 08:05 PM
blcp86
Jan 14, 2010 06:41 PM
mc_eyes
Dec 10, 2008 10:52 AM
