Off road with ABS offline.
I apologize if this is covered elsewhere in this forum, I just can't seem to find stuff readily using the search here..
I've been offroad in my wrangler, but never in the disco II and was wondering (since my ABS, TC, HDC lights are now always on due to an 'internal electrical' problem in the modulator) what difference does this make? Does the discovery rely a lot on TC offroad? Is it just as good with the modulator offline? I have the 99 disco II and have read here about locking the differential manually... what does this contribute to the offroad experience? I'm not planning anything crazy, just wanna know my limitations. The vehicle is stock.
Well it is my understanbding that Rover elminated the CDL because with the TC they felt it just wasnt needed for the average person.
I have heard two different things, 1. the TC will still work with the 3 amigos on. 2. I have also heard that the TC will not work with the 3 amigos on.
So I have no idea if it will work at all or not.
By locking the center differential you increase your traction, it will send equal amounts of power to both axles, with it un-locked it will only send power to the axle with the least resistance.
You cna lock it with a 10mm wrench, do not drive with it locked on dry roads though, to much stress and strain on the driveline that way. And it will turn like the Queen Mary.
Jim, have you actually gone and had the ABS codes read and cleared? Do your brakes squeak? If you do a panic stop from 30 MPG, do you feel your ABS pulsate thru the barke pedal?
Then get back to me.
ORIGINAL: Disco Mike
I have no pulsing ABS. I stomped hard on the brakes once (for dramatic reasons when my wife and I were having a very animated argument about something stupid - it annoys the hell out of her when I do that, so I do it often.) but there was no ABS pulse. I tried again before this post and it just smoothly dove to a stop. So I think maybe I'm SOL as far as the modulator goes...
Is TC a big part of the Disco's off road performance?
On a DII yes the TC is a big part of the trucks off road prowness.
You can get a shuttle vlave repair kit for about $800, that is cheaper than a new ABS modulator.
The shuttle valve kit rebuilds the ABS modulator, the insides go bad not the outside, good as new after the fix.
www.atlanticbritish.com
www.roverlandparts.com for a used ABS modulator.
What of the cheaper shuttle valve kit for $67.95 from Atlantic British? I was just reading some success stories here about it. I think for that price, I'll go ahead and try it & have the Codes reset. I'm planning on doing the head gasket kit soon anyway cause I'm progresively losing coolant behind the engine block. Is the 'Composite' gasket kit from Atlantic British the best way to go, anyone? Other than a good torque wrench and new bolts, any surprises I should look out for? I've done the confounded coils before, and I've done head gaskets on a different vehicle so I feel pretty confident I can handle it...
ORIGINAL: JimScream
First the shuttle valve you are speaking of will not fix your problem. Most likely you will need the $800 want that has a far better repair % compared to the shoty term 20% from the original kit.
johnkbl
Jan 13, 2009 08:54 PM
