Off road lights
Old Dec 13, 2009 | 01:19 PM
xadamx's Avatar
Default Off road lights
Hey guys. I have a 94 Disco. I am having my roof rack sand blasted and repainted right now so I had to take the two off road lights off that are up top. I am already wired up for lights and now might be the time to get some better ones.
What are the most obnoxiously bright lights I can put up top with the existing wiring without having to upgrade my battery or alternator? I mean I am looking to make bears and deers run out of the woods when I turn those things on. Thanks!
Old Dec 13, 2009 | 02:33 PM
Suede's Avatar
If you truly want the brightest light, and are not going for the "look" - then a Marine Searchlight would do the trick. I've got a buddy with 4 mounted on his Hummer (one at each corner) and he can literally light up a 360 degree circle for about a mile. Turns darkness into daylight, and they are all individually remote controlled from the drivers seat.
But if you're looking to go the more traditional route, then you can't go wrong with a set of http://www.visionxoffroad.com/LED/Xmitter/ . These are the brightest "designed for Off Road" lights you'll find.
And if your more budget minded, the Pro Comp 130 watt'rs are tried and true. All depends on how much you want to spend.
thehun
Dec 27, 2010 03:41 PM
tailchaser0527
Dec 5, 2007 08:51 AM
SpeedAgent
Aug 4, 2007 03:15 PM
iJeremy
Nov 1, 2006 11:49 AM
hymlopez
Mar 23, 2006 11:29 PM
