The Official Extinct Inline Thermostat Mod Thread
Old Jul 21, 2021 | 10:59 AM
  #151
Jason_B's Avatar
I researched the allisport radiators last summer when I was getting high temps with a (non Extinct) inline stat going up mountains in high heat. I normally use my Disco in winter and it has been sitting so I never pulled the trigger. If I still have the Disco going into next summer I will probably try one out.
Old Jul 21, 2021 | 06:58 PM
  #152
discoinfernoOSV's Avatar
Started working on my in-line mod today. For the life of me, I cannot get the bolt for the sensor port out. I can't get the leverage I guess. Is it pre-sealed by any chance? or anyone have suggestions?
Old Jul 22, 2021 | 06:57 AM
  #153
Extinct's Avatar
I don't pre seal them, don't even remove them, they come installed from the factory and I ship them just like that. When I remove them to put sealant on them I usually clamp the housing in a bench vise I'm guessing maybe you don't have a bench vise, maybe clamp it to something with a pair of vise grips? or maybe slip the inlet neck over a pipe or ratchet handle and shove the pipe into the trailer hitch
Old Jul 22, 2021 | 07:44 AM
  #154
I have a bench vise, but it isn't installed yet. I'll try the pipe when I get home. Was curious how much I needed to mess with it or if I could leave it as is. Thanks.
Old Jul 22, 2021 | 02:54 PM
  #155
rikkd's Avatar
Default Thermostat Housing
Is this normal? And will it still seal when I put the gaskets and silicone on?
Old Jul 22, 2021 | 03:28 PM
  #156
Extinct's Avatar
Yours sounds tighter than most, so it might not leak if you install as is, but generally easier to remove and seal before you install on the truck so I recommend doing it while you have it off.
Old Jul 22, 2021 | 03:29 PM
  #157
Extinct's Avatar
Normal, yes it will seal.
Old Jul 22, 2021 | 04:15 PM
  #158
rikkd's Avatar
Thank you!
Old Jul 22, 2021 | 04:44 PM
  #159
While it was very tight, I was able to break it using a pipe to hold everything still. I have it setting right now, hopefully, I can do the install (and swap the rest of the system) tomorrow. Thanks for the help, and the mod.
Old Jul 24, 2021 | 01:44 PM
  #160
andino's Avatar
Finally got some free time to install the inline thermostat. Super easy to do and great results! Thanks Extinct! Truck is running at 183F on the freeway and around 190-195 around town now depending on traffic. Still have a bit of air in the system so will need to try bleeding again but overall, very happy with the results!
