Oil cap gunk, coolant?
Old Mar 22, 2019 | 06:43 PM
04in719's Avatar
Default Oil cap gunk, coolant?
Been fighting waterfall for months. Nothing seems to bleed the system
My oilfiller cap had a yelliwish/brownish reside.see picture attached
If I didn't know better I'd say coolant in oil, no?
Thanks in advance.
Old Mar 22, 2019 | 06:48 PM
04in719's Avatar
Thanks in advance.
I should also follow up that the oil in the dipstick is perfectly normal and quite clean.
Old Mar 22, 2019 | 07:59 PM
stb616's Avatar
Its probably just moisture. I've had a lot of engines do this, especially in colder weather.
Old Mar 22, 2019 | 08:20 PM
Friday Night Disco's Avatar
Check the dip stick and see if there is any type of moisture on there. If no, you are good.
Old Mar 23, 2019 | 03:43 AM
JUKE179r's Avatar
Clean out the plastic PCV valve if you have a V8.
Better yet, remove the black PCV valve and do the Best4x4 PCV mod.
Old Mar 23, 2019 | 11:25 AM
GCBurke's Avatar
Yeah thats normal with the stock pcv setup. After the pcv mod mine is completely dry.
Old Mar 23, 2019 | 04:06 PM
GCBurke's Avatar
Get a vacuum filler......quit fighting it.
Old Mar 25, 2019 | 10:59 AM
04in719's Avatar
I have the airlift tool, still can't seem to get all the air out. It'll hold vacuum so I don't think there's a leak.
CollieRover
Jun 13, 2019 06:17 AM
boncovi
Aug 1, 2017 11:11 AM
Creed0330
Apr 28, 2014 06:53 PM
disc oh no
Aug 20, 2011 02:13 PM
bookerbr
Jan 12, 2009 11:21 AM
