Oil change interval
Old Jul 30, 2016 | 10:17 PM
chubbs878's Avatar
Originally Posted by dr. mordo
I had the same issue with Rotella T. Right off the bat it sounded worse than the dirty M1 I had just drained, and then sounded worse and worse until I couldn't stand it anymore and drained it around 3000 miles. I do not have that problem with T6 or M1 TDT, which I run for 6-7k before I change, and it never sounds as bad as clean Rotella T.
Lately I'm been adding engine prolong, and I can't believe how quiet and smooth it is.
I believe you have mentioned the Prolong before. Are you using the engine treatment or oil stabilizer? It's not on the shelf anywhere around here. Do you order online? Is the M1 also 40wt? A couple of D2 owners swear by Royal Purple. I think Im going to stick with what I have been doing.
I'm also concerned that re formulating involves diluting Zinc levels even further. When the T4 hits the shelf I may begin using the Zinc additive.
Old Jul 30, 2016 | 11:13 PM
dr. mordo's Avatar
I use the engine treatment. I got several bottles when a Auto Zone was clearing them out a few years back. Amazon sells it in gallon jugs for pretty cheap, which is what I'll be buying the in the near future.
The M1 TDT is 5w-40. I'd be just about as comfortable using the T6. The only reason I prefer the TDT is because it's a Class IV synthetic, which means it was designed from scratch to be a motor oil, as opposed to a natural byproduct that was refined to work as a motor oil. Does it really matter? Probly not.
Royal Purple and Amsoil make amazing products, but I just can't justify the cost. I ran Amsoil for a while and quit when I realized that after shipping costs it was about twice as expensive as M1. I just can't believe it's twice as good of an oil.
You bring up an interesting point about the ZDDP being diluted. I was looking at virgin oil analyses earlier, and was surprised to see that Chevron's Delo 5w-40 has a bit more ZDDP than the T6 or M1 TDT. That said, I think these trucks have too much oil in them anyway, especially with the mondo filter some folks run. I'm not too worried about dilution.
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
tito5590805
Oct 4, 2010 09:11 AM
ranger5oh
Nov 30, 2009 07:12 PM
Dan_da_LR3_H2_man
May 28, 2009 11:37 AM
