Oil Cooler Install
Old Nov 17, 2016 | 04:31 PM
LR03NJ's Avatar
Default Oil Cooler Install
Cooler installed but not sure if its for transmission or for engine
I would like to install a factory oil cooler for the disco. But i found out that there is one already installed. Im not sure if its a transmission or engine oil cooler installed. Got pictures here.
Old Nov 17, 2016 | 06:34 PM
PalmettoDisco's Avatar
I believe all models had engine oil cooler and 99-02 had the similar separate transmission fluid cooler. If your rover has a single cooler then it is a 03 or 04 engine oil cooler. The transmission fluid coolers have an electrical temp sensor attached to bottom of one end, as I recall.
Old Nov 17, 2016 | 06:39 PM
Red5's Avatar
Actually the earlier years had both but the oil cooler was omitted from later models, not sure what year. My 04 does not have one.
If you have only one, it's the trans cooler.
Old Nov 17, 2016 | 10:59 PM
abran's Avatar
That photo Is an 03'/04' trans cooler.
The cool kids take that cooler and use the cooler lines from a 99'-02' and add it as an engine up cooler.
That cooler is the largest cooler Land Rover put in the D2s.
Old Nov 17, 2016 | 11:15 PM
Robert Booth's Avatar
Somewhat relevant topic: has anyone found a source for new D2 oil cooler lines? They've been discontinued.
Old Nov 18, 2016 | 10:07 AM
abran's Avatar
I have, but the price is crazy. Like over $300 for one.
Old Nov 18, 2016 | 10:26 AM
CollieRover's Avatar
I have been considering getting an oil cooler and one of the sandwich adapters that go above the oil filter.
Old Nov 18, 2016 | 12:04 PM
LR03NJ's Avatar
If the other get installed, it will almost block the radiator air passage. Am I gaining anything here? Seems like the main radiator wont get enough air to cool the coolant. but I'll try it somehow if the pipe is long enough to reach. I still remember the temperature before the HG replacement.
Old Nov 18, 2016 | 12:30 PM
abran's Avatar
I have added the larger trans cooler as a engine oil cooler and there was no change in my coolant temps(04' D2)
Old Nov 18, 2016 | 12:58 PM
Jeff Blake's Avatar
There are 2 different front covers, oil cooler type and non oil cooler type. I just found this out myself as I'm in the market for a replacement. I originally thought the covers were the same, and the oil cooler port was simply blocked off on 03/04. Hm.
See: 4.0V8 Front Cover & Oil Pump - Land Rover Engine Parts
