Oil cooler kit?
Oil cooler kit?
Does anyone make an oil cooler kit for the 04 D2?
Will a stock oil cooler from a previous year D2 fit?
I'm sure I can piece something together, but it would be nice if someone had correct length lines, fittings, and mounting hardware.
Knocking the oil temperature down a couple degrees couldn't hurt.
Thanks for any info.
I was going to put one in, too. I decided against the stock due to the difficulty in finding the lines/pipes.
Summit racing has a bunch of oil coolers, and of good size. There are screw holes so you could fabricate an aluminum bracket, but certainly not going to bolt in like a stock.
I also considered a pancake adapter for the oil filter and a stock cooler, but just have not had the time to research how to connect the two.
What I would really like to do is mount one with a fan below the frame in the bumper that way the hot air is blown below the vehicle and not introduced to the cooling system, but I have not seriously researched that option yet.
Sixpack577 (05-17-2018)
There are 3 threaded holes with caps on the timing cover. 1 directly above the filter, and I have an adapter there for an oil pressure gage.
There is another above and below it, these are the 2 for the oil cooler lines.
I can get fittings with barbs, but would prefer to have a hydraulic style line with crimped ends.
I was wondering where to put the cooler itself too(with the ac condensor and front electric fan already there.
I like your idea of an electric fan on the cooler too, which opens up options of where it could go.
Hopefully we'll get some more replies.
Thanks!
Thanks!
Thanks!
Thanks!
I like your idea of in the bumper, and with a fan.
Hopefully there would be a good spot in some of the aftermarket ones.
I have some other repairs to do first.
