Oil Drain plug loose
Old Jul 31, 2019 | 09:43 PM
Richard Gallant's Avatar
Default Oil Drain plug loose
After 4 days of off roading noticed a leak under my Disco, turn out the drain plug had come loose, very loose. I am assuming the crush washer is shot.
Will any 9/6th oil plug crush washer work ?
Old Jul 31, 2019 | 09:48 PM
Nosugar0carbs's Avatar
An aluminum or copper crush washer. Possibly safety wire would help
Old Aug 1, 2019 | 06:50 AM
JUKE179r's Avatar
In a pinch you can rub the old washer across a sheet of sand paper and on a flat surface to flatten the face of the washer.
Or like @Nosugar0carbs mentioned, get an aluminum or copper washers as replacements.
Old Aug 1, 2019 | 10:24 AM
Copper replacement should be easy enough, good auto parts stores here.
Thanks all
Brandon318
Apr 24, 2019 07:35 AM
themdg
Jan 25, 2015 01:52 AM
spiderss
Jan 20, 2015 06:41 AM
buick215
Jan 7, 2012 04:25 PM
hendoc3
Jul 20, 2007 03:44 PM
