Oil drain plug replacement
Old Jun 19, 2017 | 04:51 PM
TRIARII's Avatar
Default Oil drain plug replacement
Found nothing relevant to my questions in search. The oil drain plug does not tighten up firmly anymore so I need to replace the plug. I can order one online but I was wondering what the specs of the plug/bolt are so I can try and hunt something down at a local hardware store.
Old Jun 19, 2017 | 06:27 PM
abran's Avatar
you might need to overbore and tap your pan. Sounds like the threads are going if it won't tighten.
Old Jun 19, 2017 | 06:47 PM
OverRover's Avatar
OE ( LSF100040L ) size is M14 X 1.5 (IDK the length), but as abran pointed out you will probably need to oversize the plug or use a Timesert. If you are looking at a local auto parts stores try a Dorman 65217
Old Jun 19, 2017 | 07:12 PM
Bom2oo2's Avatar
X2,,^
Oil pan Aluminum threads can't wear steel bolt threads,
Old Jun 19, 2017 | 09:22 PM
TRIARII's Avatar
Never heard of over overboring. How do I do that exactly? Just did a oil change yesterday so Id hate to have to drain all the oil. I may end up buying an extra washer and aome rtv to hold things over until the next 3k oil change.
Thanks for the info
Old Jun 19, 2017 | 10:00 PM
KingKoopa's Avatar
You would need to remove the bolt to apply the rtv and new washer so you are screwed anyway. Just collect the oil in a clean pan and reuse it.
You needed to drill the hole in the oil pan to the next largest size, and then tap threads in the new hole. Then purchase the bolt to match. Like the others said, the bolt is steel and the pan is aluminum, rock beats scissors.
Old Jun 19, 2017 | 10:01 PM
KingKoopa's Avatar
Or a helicoil will probably working as well.
Old Jun 19, 2017 | 10:12 PM
abran's Avatar
Also some teflon tape on the threads might buy you an oil change or 2.
you could also try teflon tape, RTV, and a Fumoto drain valve as a permanent solution.
Amazon Amazon
Old Jun 19, 2017 | 10:26 PM
Not sure why one would risk a newish motor over a 5 quarts of oil
Old Jun 20, 2017 | 10:53 AM
Friday Night Disco's Avatar
How much is a new oil pan and gasket?
