Oil drain plug replacement
Found nothing relevant to my questions in search. The oil drain plug does not tighten up firmly anymore so I need to replace the plug. I can order one online but I was wondering what the specs of the plug/bolt are so I can try and hunt something down at a local hardware store.
Thanks for the info
You would need to remove the bolt to apply the rtv and new washer so you are screwed anyway. Just collect the oil in a clean pan and reuse it.
You needed to drill the hole in the oil pan to the next largest size, and then tap threads in the new hole. Then purchase the bolt to match. Like the others said, the bolt is steel and the pan is aluminum, rock beats scissors.
