Oil Leak
RE: Oil Leak
That plate on the transfer case is the "inspection plate".
Land Rover use liquid gasket at the factory to seal it.
I drained my transfer case, removed the inspection plate, cleaned off all the gunk and refitted the plate
but with a paper gasket which was listed in the spare parts guide for a Discovery Series I transfer case.
It matches perfect.
Leak gone!
That was 4 years ago. Now it looks like its leaking again. [&:]
Those leaky gaskets are the bane of Land Rover owners.....
on
RE: Oil Leak
ORIGINAL: melmanc55
I have 52k miles on it. What is he milage on the warrenty. You may be right.
As mentioned, if it is the inspection plate, do anafternoon project and do a quick reseal. If it is not t/case tell us what it is that you suspect to be leaking.
Mike
thearmlesswonder
07-27-2015 10:16 AM
Phatrowles
01-09-2014 10:36 AM
