Oil Leak
Old Sep 13, 2006 | 12:12 AM
melmanc55's Avatar
Default Oil Leak
I have a 04 discovery. There is a plate right next to the oil drain (with six bolts on it). Looks like that where the leak is (around the gasket). Anyone had this problem before and know the est. repair cost is. Thanks for any replies.
Old Sep 13, 2006 | 11:23 AM
Default RE: Oil Leak
Aren't you under warranty???
Take it to the dealer and have them fix it.
Mike
Old Sep 14, 2006 | 12:05 AM
melmanc55's Avatar
I have 52k miles on it. What is he milage on the warrenty. You may be right.
Old Sep 24, 2006 | 12:25 PM
tempestv8's Avatar
That plate on the transfer case is the "inspection plate".
Land Rover use liquid gasket at the factory to seal it.
I drained my transfer case, removed the inspection plate, cleaned off all the gunk and refitted the plate
but with a paper gasket which was listed in the spare parts guide for a Discovery Series I transfer case.
It matches perfect.
Leak gone!
That was 4 years ago. Now it looks like its leaking again. [&:]
Those leaky gaskets are the bane of Land Rover owners.....
Old Sep 24, 2006 | 12:30 PM
ORIGINAL: melmanc55
4 years or 50,000 miles, Sorry.
As mentioned, if it is the inspection plate, do anafternoon project and do a quick reseal. If it is not t/case tell us what it is that you suspect to be leaking.
Mike
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
