Oil Leak 99 Disco 1
Old Feb 21, 2010 | 12:02 PM
JHarry's Avatar
3rd Gear
Default Oil Leak 99 Disco 1
I lost the tension pulley which pulled the belt off. After replacing the pulley and belt, started the car and it is now leaking oil from what looks like the crank shaft pulley. Please help.
Old Feb 21, 2010 | 01:57 PM
How bad is it leaking?
You can have that front crank seal replaced for not very much money.
It is $2 part and maybe a couple of hours labor.
Old Feb 21, 2010 | 10:35 PM
unimoged's Avatar
No relationship exists between losing a belt and starting an oil leak unless the belt and the tensioner mangled something in the front of the engine. Do you see any damage there.
Old Feb 22, 2010 | 10:43 AM
JHarry's Avatar
3rd Gear
What ever happened with the pulley and belt wasn't the oil leak. That was caused by the Harmonic Balancer breaking into six pieces. Hope that is all the damage that was done. Trying to find a Harmonic Balancer now. Good luck to me.
Old Feb 22, 2010 | 10:56 AM
www.autosportsunlimited.com
www.roverlandparts.com
www.car-part.com
Old Feb 25, 2010 | 11:08 AM
JHarry's Avatar
3rd Gear
Good for me, was able to locate the part in the area. Dealer had no idea when he would even be able to get one. He said he couldn't find one anywhere in the US. Well I'll let you know if any other damage was done once I get it back up and running. Have my fingers crossed. Thanks for the replies and help.
Old Feb 25, 2010 | 11:12 AM
okdiscoguy's Avatar
If you are having it done, have them at least throw a new front crank seal in. I would suggest pulling the front cover and replacing the timing set and the oil pump gear set, depending on your oil pressure numbers. I would throw a new water pump and t-stat in while you have it apart.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
