OIL LEAKS
Old Jun 22, 2008 | 02:09 PM
woodlander's Avatar
Default OIL LEAKS
my 95 disco is leaking oil and atf pretty bad. are there common spots and hoses to check. if so are there hose kits availible to solve the leaking for good? thanks guys
Old Jun 22, 2008 | 02:35 PM
ljdiscovery's Avatar
Default RE: OIL LEAKS
First, get under the truck and clean everything with simple green or some other oil/engine cleaner (simple green does a great job and is much less damaging if you get it in you face/eyes. Clean from from to back several times so it is easier to tell where the leaks are originating. Then front crank seal, timing cover, oil cooler lines, in and out, transmission cooler lines, in and out. Check the valve cover gaskets. I just did my oil cooler lines, not too tough but it is worth investing in some shorter wrenches that will fit, space is tight. I ended up using an open ended adjustable wrench 6". Front crank seal is a little tougher, some independant shops have quoted $110 to $190 including parts. Good Luck. Phil
99 Discovery I 89,000 miles
Old Jun 22, 2008 | 04:08 PM
Crawl under and look for your self, this is not rocket science.
Let us know what you see then maybe we can help you.
Old Jun 22, 2008 | 07:09 PM
The best way that I ahve found to clean the underside of your trk is to take your ramps to the DIY carwash, degrease the whole engine, top to bottom, underside really well including the front axle.
Drive it home and you will beable to find your leaks.
ljdisco told you about the most common ones.
Old Jun 24, 2008 | 09:53 AM
woodlander's Avatar
thanks guys
Spencerfitch
Sep 27, 2020 12:17 PM
austinlandroverbill
Aug 23, 2015 01:03 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
Derek
Feb 17, 2013 07:37 PM
discoboy
Dec 20, 2012 02:24 AM
