OIL LIGHT
Old Dec 28, 2007 | 11:43 AM
newdr's Avatar
Default OIL LIGHT
RARELY THE OIL LIGHT COMES ON OR FLICKERS WHEN THE ENGINE IS RUNNING SLOW AND ROUGH RIGHT AFTER STARTING.
CONCERNS?
Old Dec 28, 2007 | 01:00 PM
okdiscoguy's Avatar
Default RE: OIL LIGHT
first, check your oil level. That light is telling you the pressure is below what it should be. Might want to do an ATFflush (search on here) and then drop you pan and clean everything out..
Hard to give good suggestions without the year and mileage....if
Old Dec 28, 2007 | 01:20 PM
newdr's Avatar
OIL LEVEL IS GOOD.
2003, 80K
Old Dec 28, 2007 | 01:42 PM
jdelp's Avatar
ATF flush isn't a bad idea if sludge is the culprit, but if you do a search on these forums you'll find that the 2003 Disco's were prone to oil pump failure and catastrophic engine failure as a result. I'd be on the safe side and get your oil pressure checked before you do any more driving; Atlantic British is having a sale on new motors, but I think you'd like to avoid that
Old Dec 28, 2007 | 03:24 PM
Some 03's had bad oil pumps from the factory, maqny people have lost their engines over this issue. I would suggest you call me so I can walk you thru what to do ASAP before you become of of those unfortunate ones.
303-862-7680
Colorado
Between 7 am and 8 pm
Old Dec 28, 2007 | 04:02 PM
okdiscoguy's Avatar
X2 on that. I was going to add that if yours is an 03, you could have big problems lurking. Call Mike...
Old Dec 30, 2007 | 08:37 AM
howellja's Avatar
"I was going to add that if yours is an 03, you could have big problems lurking."
I dont know if im going to be able to sleep! Luckily I bought an extended warranty if she doesblow!I have a 2003 that has just started to develop some lifter noise/valve tapon the passenger side. The last time I changed the oil it was about a half court low but couldnt find a leak. What do you guys advise? I was going to do an ATF engine flush and have the oil pressure checked in the next couple of weeks. SHould i have the pressurechecked first thendo the clean out?Should I be ordering up an oil pan gasket for this piggy just in case I need to drop the pan and clean out pickup tube? Disco Mike?
Old Jan 22, 2008 | 04:47 PM
newdr's Avatar
I HAD A DEALER FIX THE PROBLEM. SLUDGE. OIL PRESSURE WAS GOOD WHEN COLD BUT BELOW SPECS WHEN WARM. FIXED BY REMOVING THE OIL PAN ($460)
Old Jan 22, 2008 | 05:50 PM
okdiscoguy's Avatar
I just did another flush and finally pulled my pan this weekend. I had new sawy bar end links to install, so I figured what the heck. I am glad I did. I noticed a slight tick when i would run my RPMs up. The pickup tube was clogged, oil passages were gross in the heads and the pan was goopy. I decided to pull the valve covers, intake and valley pan after seeing the oil pan. Should have just gotten a head gasket kit and sent the heads off while I was in there, but I really like doing things twice.
She runs like a champ. I was floating a lifter, I am guessing due to a clogged oil port. luckily, the cam looked ok. This also cured my 2500 RPM vibration. I pulled about 1.5 quarts of sludge out and I could eat off the inside now. Can't wait till spring to pull the heads and see what the combustion chambers look like...
devildollnyc
Dec 25, 2018 05:12 PM
mikec205
Nov 18, 2014 07:37 AM
drewski
May 31, 2013 10:50 AM
tacker
Jul 10, 2010 09:36 PM
shagybruce
Feb 8, 2007 02:52 PM
