oil light coming on
Old Oct 27, 2013 | 09:32 AM
wkburns's Avatar
Default oil light coming on
I have a 2004 Discovery with a 140 thousand on it. Last year just to be preventative I replaced the oil pump. Lately it appears the idle is lower than normal and as a result the oil light comes on. If you shift into neutral the engine revs slightly and the light goes off. Would this issue be related to the cam shaft position sensor or something else? It does not happen all the time, just when the rpm seems to drop below 700rpm at idle. Thanks for any help.
Old Oct 27, 2013 | 02:26 PM
oilspotLR's Avatar
What type of oil are you running?? You should do a PSI test to see what your actual oil psi is.
Old Oct 27, 2013 | 06:27 PM
wkburns's Avatar
Rottela 15W-40
Old Oct 27, 2013 | 08:53 PM
X2 on the manual gauge test. Might have sludged up oil pickup, etc.
Rock Sing
Mar 2, 2013 02:01 AM
Rock Sing
Mar 1, 2013 12:35 AM
srockrae
Sep 3, 2012 06:08 PM
bangkuaidiscovery04
Feb 7, 2010 09:31 AM
johnboyairey
Oct 15, 2008 06:16 PM
