Oil light - now you see it, now you don't
Old Feb 5, 2012 | 09:54 AM
1/2 X 20 thread for the switch, 1/8 npt usually for the test gauge. If possible, take switch with you to store, or test with theirs in the store. This way, you have already found out what a PITA it can be to get at in some cases with oil cooler lines and big hands. There was also an O ring behind the switch, go ahead and replace.
Old Feb 5, 2012 | 02:21 PM
steveo2000's Avatar
Thanks guys for all of your responses! I'll report back my findings.
Old Feb 5, 2012 | 02:42 PM
honda50r's Avatar
Originally Posted by Disco Mike
First, go rent a oil pressure tester from a local parts store, may need to buy an adapter so you can screw it in in-place of your oil pressure sender. Then on a cold start, test the pressure at idle and 2000 RPM's again when hot at idle and 2000 RPM's and get back to us with the 4 sets of numbers.
As for the weight of oil causing this, won't happen during the cold months so take your oil/weight and brand out of the picture for now.
Let us know what you find.
You're right, I need to stop being a cheap ***.
Old Oct 30, 2024 | 08:31 AM
Mo 3's Avatar
Originally Posted by honda50r
I'm a D1 guy and have somewhat similar problems. My oil light actually flickers, but only at low RPM's and only when warm.
I have my Rotella Diesel and oversized Napa filter ready to go. I shall see if this cures my problems. Thoughts?
on D1 the actual oil pressure sensor is prone to going bad I remember changing it every 6-8 months on my d1 lucky they are cheap
uoflcardfan77
Aug 6, 2015 03:47 PM
calebbo
Oct 12, 2011 09:54 PM
lipadj46
Oct 7, 2010 11:19 AM
Street Wolf
Appearance & Camping Set Ups
Jul 3, 2009 02:32 PM
05LandRover
Sights N Sounds
Apr 27, 2005 01:14 AM
