Oil light and other questions
Old Mar 11, 2010 | 09:33 AM
cathaan's Avatar
6th Gear
Default Oil light and other questions
Hey guys, I've got a 2000 discovery with around 92k miles on it.
I just had it in the shop a couple of weeks ago and had a bunch of
stuff replaced... Intake manifold gasket, radiator hoses, ignition coils etc.
Truck seems to be running fine, but after the engine warms up, when I'm at idle
the oil pressure light comes on. Once you press the gas it goes right back off.
I have checked the oil level and even did a full oil change last weekend.
Also, the oil has developed a grey color and I'm really worried that something is leaking.
Any thoughts on what could be wrong? My mechanic said it might be a faulty pressure
sensor. I'm hoping I can get back to him in the next few days.
Old Mar 11, 2010 | 09:36 AM
okdiscoguy's Avatar
STOP DRIVING IMMEDIATELY!!!
You have low oil pressure and the grey tint is bearings destroying themselves! Do not drive it to the shop, have it towed to have the pressure tested. That sensor kicks at 8PSI. normal pressure should be in the 30's. Not trying to scare you, but you could be killing your engine.
Old Mar 12, 2010 | 09:45 AM
You should be worried, as already mentioned, "STOP driving it" and have it towed to a shop where they can verify the oil pressure when cold and when warmed up.
Let us know what you find.
Snafu / Disco Fries
Mar 11, 2021 06:39 PM
adam123
Apr 5, 2011 09:11 AM
tsuami1
Feb 1, 2011 09:57 AM
mantle33
Jan 25, 2009 07:24 AM
xb70valkarye
May 30, 2006 12:52 PM
