Oil light question
Old Feb 1, 2010 | 08:38 PM
okdiscoguy's Avatar
If you didn't swap the ECU, you may need to take it to the dealer to have it set. Sometimes when replacing the TPS or stepper, it needs to be read by a scanner before the value is corrected. YOu can try replacing the steeper with your old one first if you want..
Old Feb 1, 2010 | 08:43 PM
reddevildemo's Avatar
Ok, thanks. I will try and replace it with the original stepper and see what happens.
Old Feb 1, 2010 | 09:31 PM
Remember, your ECU thinks the engine still has 80k (or whatever your old one had on it) so it is running the 34k engine off of the 80k mapping.
Old Feb 2, 2010 | 05:26 AM
Thanks Spike. That is one thing I never thought about. I'll run it to the dealer this week and see if that takes care of the issue. I'll let everyone know how much that runs me.
Old Feb 2, 2010 | 08:47 AM
okdiscoguy's Avatar
Shouldn't be much more than $100.. drop in the bucket. =)
Old Feb 2, 2010 | 08:54 AM
That is what I was thinking too.
I will get my surging cruise control issue fixed at the same time.
Old Feb 2, 2010 | 09:07 AM
okdiscoguy's Avatar
sounds like a tps to me... just needs to be hooked up to a computer. I would throw your old throttle assembly in just in case they want to swap parts.
devildollnyc
Dec 25, 2018 05:12 PM
mikec205
Nov 18, 2014 07:37 AM
drewski
May 31, 2013 10:50 AM
tacker
Jul 10, 2010 09:36 PM
shagybruce
Feb 8, 2007 02:52 PM
