Oil in my water pump?
Old May 28, 2013 | 10:18 AM
drowssap's Avatar
the red you are seeing is definitely gasket sealer
Old May 31, 2013 | 12:19 PM
flanker6's Avatar
Originally Posted by SuperSport
I've used gasket sealer that looks exactly like the red in that photo, that would be what I'd think it is. Especialy if it does not just wipe off. It feels a little like hard rubber cement that's dried.
PS: The photos don't seem to be showing anymore. I'm guessing that's why nobody else mentioned gasket sealer.
Thanks man, it is sealer.. The photos are from my instagram account and take forever to load.
Old May 31, 2013 | 02:16 PM
SuperSport's Avatar
No problem, I'm glad that's all it was. Your miricle has happened!
I can just imagine how your heart sank when you first saw it and didn't recognize it. But I bet you'll recognize it next time.
Old May 31, 2013 | 03:04 PM
flanker6's Avatar
No doubt! I was thinking about how I was going to change my head gaskets this weekend.
Never fear: She will have much more for me to tackle.
Old May 31, 2013 | 08:25 PM
BCDisco2Lando's Avatar
If oil was coming out of water pump, then oil would also be in coolant or vice versa. As mentioned, coolant pressure tester, and closely examine. There is no oil behind the water pump gasket, but there is behind the front cover gasket. Seems like kit of both gaskets, new oil pump gears, front seal - runs about $110. But budget for a water pump and new fan clutch as well. Exam the timing chain for slop while open. And with oil pan off clean the pickup screen and renew the seal on the pickup tube.
I agree with Savannah,
The pic of the gasket in the second pic from the left is of my engine and the issue was never the head gasket. The first owner changed the head gaskets but still had oil mixing with the coolant. After we bought the Lando I ripped the engine out and discovered the timing cover gasket was what failed. Now we are doing a complete rebuild because the oil/water mix destroyed the main and rod bearings.
A5scott
May 18, 2015 06:34 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
ljdiscovery
Feb 27, 2010 06:57 PM
adwarren78
Jan 19, 2010 05:40 AM
