Oil pan gasket ?
Oil pan gasket ?
hey folks !!
in the process of doing the head gasket replacement ( heads are @ the machine shop now), there was enough gunk laying in the heads , although the lifter valley was fairly clean, that i decided I should remove the oil pan and give her a good cleaning as well, my question is....should I buy the oil pan gasket or use the black rtv sealant,
also what's the general opinion of replaceing the lifters at this point, i dont see any abnormal wear ??
thanks for your input !
'98 DI, 150,000 miles
thanks for the input all !
I guess I was on some good stuff this evening as I thought the pan would come off (out)without removing the steering arm........but it's off. this had some kind of silly goop on it and not a gasket. I've had other vehicles with "cork " gaskets on the oil pan and it always seems that they leak ....so I guess I'll flip a coin ?!
