Oil pan gasket ?
Old Jul 27, 2009 | 10:01 AM
XCELLER8's Avatar
Question Oil pan gasket ?
hey folks !!
in the process of doing the head gasket replacement ( heads are @ the machine shop now), there was enough gunk laying in the heads , although the lifter valley was fairly clean, that i decided I should remove the oil pan and give her a good cleaning as well, my question is....should I buy the oil pan gasket or use the black rtv sealant,
also what's the general opinion of replaceing the lifters at this point, i dont see any abnormal wear ??
thanks for your input !
'98 DI, 150,000 miles
Old Jul 27, 2009 | 10:18 AM
I see people go with the paper gasket, some with sealant and others us sealant only, pretty much all works the same.
Old Jul 27, 2009 | 01:47 PM
Rover Curious's Avatar
The oil pan gasket I got for my truck is rubber. Haven't put it on yet, so can't tell you about fit or ease of installation, but the gasket that came off was rubber too, and I've never had a leak around the oil pan attachment area.
Old Jul 27, 2009 | 02:26 PM
jycsalas's Avatar
The DII gasket is rubber and the DI gasket is cork/paper. They are very different.
DII
DI
Old Jul 27, 2009 | 09:20 PM
XCELLER8's Avatar
thanks for the input all !
I guess I was on some good stuff this evening as I thought the pan would come off (out)without removing the steering arm........but it's off. this had some kind of silly goop on it and not a gasket. I've had other vehicles with "cork " gaskets on the oil pan and it always seems that they leak ....so I guess I'll flip a coin ?!
mike111
Jun 2, 2014 08:58 AM
jpmiller
Sep 26, 2012 06:32 AM
afphinfan
Jan 5, 2008 11:04 AM
91rover
Jun 13, 2007 03:15 PM
modelwerks
Oct 13, 2005 05:39 AM
