Oil Pan stuck
I went through thus my self and unless you have a stick of dynomite handy your're just going to have to gently pry the pan down . A bf screwdriver or stiff flat gasket scraper usually will do the trick, and while you're there you might as well plan on removing the pan so as to clean it out and clean the sealing surfaces.....ya don't want to do this twice huh ?
unfortunately.....you may have to remove a steering arm on one side to gain enough room to get the pan out,
good luck
good luck
