Oil Pressure light at Idle
Old Jun 12, 2009 | 10:26 PM
DanR's Avatar
Default Oil Pressure light at Idle
Firstly I have done a search and did not find what I was looking for
my )4 disco has in the las tweek developed an issue at idle where the oil light will come on. Rev it above 1k and the light goes off.
Was thinking to do an oil change and see if that helped as I had to put 1 quart of 0-40w min last week as I was low on oil
Thoughts?
Old Jun 13, 2009 | 12:55 AM
NiteTrain's Avatar
I've seen this with other vehicles and the solution is as simple as cleaning the oil sending unit connection. Best thing to do is put an oil pressure testing gauge on your engine and find out your true oil pressure.
Old Jun 13, 2009 | 07:16 AM
How long have you owned the truck?
0w-40 is to thin for the summer time (unless you live in Antartica), when oil gets hot it thins out and if it gets to thin it wont hold oil PSI.
10w-40 is a way better choice for these trucks.
Old Jun 13, 2009 | 08:32 AM
Quit driving it and have a full oil pressure test done from cold at idle and at 2000 RPM's and when warm from idle and 2000 RPM's and get back to us with the numbers.
Quit using that 0W/40 oil and get up towards a 10W/40 plus for summer driving.
drewski
May 31, 2013 10:50 AM
eaglewing
Apr 16, 2011 11:06 AM
meltdowndave
Jan 30, 2010 06:56 PM
DooDer
Jan 12, 2010 10:46 PM
dinandan
Apr 23, 2008 09:17 AM
