Oil pressure question for the guru's
OK so I was finally able to find a fitting to getan oil pressuretest gauge on my Disco. Used a 5/16 compression fitting to a ¼" NPT, then a 1/4-1/8" reducer.
Cold:
Idle (~700rpm) 35 PSI
2500rpm = 38 PSI
Normal running temp: (~75°f ambient)
Idle = 20-24 PSI (seemed to vary a bit)
2500rpm = 33-34 PSI
Normal running temp: (~45°f ambient)
Idle =~30 PSI
2500rpm = 35-36 PSI
Castrol 20-50W oil.
Do these readings look about normal to the veterans out there? Or do I have issues?
Manual states pressure should be 40PSI @ 2500rpm at normalrunning temperature. Seems to have best pressure when engine is semi warm, where I'll get the 40PSI reading @ 2500rpm. Seems the hotter the engine & the day, the weaker the oil pressure (thinner oil?).
Cold:
2500rpm = 38 PSI
2500rpm = 33-34 PSI
Idle =~30 PSI
2500rpm = 35-36 PSI
Castrol 20-50W oil.
Thank you Mike! You told me exactly what I needed to know. (and wanted tohear)I kind of figured that in the "real world" and a well "broken in" motora reading less than 40 psi would be acceptable. Just how low was what I was wondering. I can relax a bit now! Thanks again.
