Oil pressure question for the guru's
Old Dec 9, 2007 | 09:34 PM
mordor110's Avatar
Default Oil pressure question for the guru's
OK so I was finally able to find a fitting to getan oil pressuretest gauge on my Disco. Used a 5/16 compression fitting to a ¼" NPT, then a 1/4-1/8" reducer.
Cold:
Idle (~700rpm) 35 PSI
2500rpm = 38 PSI
Normal running temp: (~75°f ambient)
Idle = 20-24 PSI (seemed to vary a bit)
2500rpm = 33-34 PSI
Normal running temp: (~45°f ambient)
Idle =~30 PSI
2500rpm = 35-36 PSI
Castrol 20-50W oil.
Do these readings look about normal to the veterans out there? Or do I have issues?
Manual states pressure should be 40PSI @ 2500rpm at normalrunning temperature. Seems to have best pressure when engine is semi warm, where I'll get the 40PSI reading @ 2500rpm. Seems the hotter the engine & the day, the weaker the oil pressure (thinner oil?).
Old Dec 10, 2007 | 07:40 AM
Default RE: Oil pressure question for the guru's
You have a 12 year old truck with some mileage wear so you won't get the factory oil pressure numbers, but the good news is that is great oil pressure for your truck.
Old Dec 10, 2007 | 09:50 PM
mordor110's Avatar
Thank you Mike! You told me exactly what I needed to know. (and wanted tohear)I kind of figured that in the "real world" and a well "broken in" motora reading less than 40 psi would be acceptable. Just how low was what I was wondering. I can relax a bit now! Thanks again.
wynhd
Aug 31, 2012 04:13 PM
HOSER
Apr 16, 2012 04:18 PM
DiscoIIBrandon
Jul 13, 2011 09:25 PM
0304Disco
Mar 31, 2011 04:42 PM
bmccool21
Feb 9, 2010 08:41 AM
