Oil Pressure Relief Valve O-Ring
Measure the original O-ring and find a match here:
http://www.allsealsinc.com/pdf/Natio...atalogue-1.pdf
Usually you find that size in local hardware or part stores. I already went that way for a couple of o-rings (steering fluid reservoir, camshaft sensor). If you found a good match pls. post the number here.
