Oil pressure /ticking issue
Old Sep 9, 2018 | 10:54 AM
EAustin494's Avatar
Okay I don’t have the adapter to put the oil pressure gauge in yet but I have a ecu reader. Out of the three times I have tried it so far the ticking starts at 128 degrees F and 134 degrees F then 140 degrees. Does that indicate a slipped sleeve?
Old Sep 9, 2018 | 07:01 PM
Extinct's Avatar
Sounds like it bud, sorry. Also, given that it starts at a low temperature, a low temp thermostat will probably not fix it. Oil pressure will tell us for sure, only way it is something other than slipped sleeve is if the oil pressure is so low it has a lifter or rocker tick, but that is more uncommon than common. Others have done the pinned liner repair, or you could put in a replacement engine. If you go the replacement engine route I would get a 2002 or earlier 4.0, they never have slipped sleeves. There was a low mileage one for sale on the forums a week or so ago with trans and transfer case for $750, I pretty good deal.
Old Sep 9, 2018 | 08:17 PM
EAustin494's Avatar
I am assuming that the pinned liner route requires a machine shop that will do it. I will look up details in the forums here. I will post as soon as I get oil pressure numbers. Thank you for your help.
Old Sep 9, 2018 | 09:14 PM
Charlie_V's Avatar
You can do it yourself from under the truck, but it is better on an engine stand.
Flanged liners, or any new liner, definitely requires a shop.
Old Sep 11, 2018 | 01:13 PM
Fast951's Avatar
A walked cam bearing will transmit noise right up through the lifters to the tappets, so don't rule that out.
Old Sep 11, 2018 | 02:04 PM
EAustin494's Avatar
Can i see that when I pull the oil pan?
Old Sep 11, 2018 | 07:38 PM
Extinct's Avatar
Yeah, you can. But oil pressure reading will tell you if you have a walked cam bearing. Oil pressure will be very low.
Old Sep 11, 2018 | 07:40 PM
Charlie_V's Avatar
it would be hard to see past the crankshaft. This is a view from the top with the upper and lower intake removed. The box shows the cam in the valley and the lines point to where the cam bearings are. If the cam bearings were walked, you might see them here.
The second picture is looking up with the oil pan off. From a better angle, with your head just so, and a good flashlight, you might see them.
Yeah, I know, this engine was a mess. But as the previous poster noted, if the bearings are walked you will have low oil pressure. It would be easier and cheaper, considering the gaskets and / or fluids lost for a peek, to check the oil pressure and go from there.
anbran
Jul 20, 2018 12:35 PM
escott16
Jun 13, 2018 04:14 PM
bcolins
Oct 18, 2016 07:06 PM
velija
Mar 11, 2014 01:59 PM
gusbone
Mar 3, 2012 09:18 AM
