oil problem
Old Dec 6, 2018 | 08:44 AM
rach's Avatar
Default oil problem
Hi
here I have a land rover discovery 2 TD5 2002,
my problem is that the oil mixes with the water,
and I'm afraid that is a serious problem
need to know more about the problem, and how do to repair
thank you
cordially
Old Dec 6, 2018 | 09:30 AM
Best4x4's Avatar
Could be as simple as a bad front timing cover gasket or as bad as HG’s to a cracked block.
Old Dec 6, 2018 | 10:23 AM
Richard Gallant's Avatar
You have diesel engine so most likely head gaskets and yes that is a serious problem. The repair is to replace the head gaskets.
But you did not tell us how you know there is water in the oil
Is it this issue : https://www.4x4community.co.za/forum...ing-Light-quot
Or is your oil kinda of milky white ?
Old Dec 6, 2018 | 10:45 AM
Best4x4's Avatar
TD5 = missed that, but yep HG’s.
Old Dec 6, 2018 | 12:04 PM
rach's Avatar
thank you for
, sorry guys, apparently I did not express well,
first this diesel engine,
and the problem that the oil that has entered in the water system (I noticed that the water bottle is filled with oil), I found on the internet that there may be a problem in the oil cooler
thanks again
Old Dec 6, 2018 | 06:06 PM
The Deputy's Avatar
Yes, if you have oil in your coolant...check oil cooler. Oil in the anti-freeze is a totally different problem than coolant in the oil.
​​​​​​​ Brian.
Mike53
Oct 17, 2018 12:07 PM
Abdul Muhaimin
Other
Jun 2, 2018 09:50 PM
04duxlr
Sep 29, 2014 07:09 PM
5150fab
Feb 22, 2013 10:20 AM
defcruiser
Defender
Mar 26, 2007 07:00 AM
