Oil psi numbers
Old Feb 20, 2013 | 11:43 AM
MC04DII's Avatar
Default Oil psi numbers
Are these numbers ok?
I get btwn 17-24 at operating idle
50-52 at cold start
40-48 at 2k on the highway operating temp.
The last one worries me since rave says 50 psi at this setting. Is that a max number, or is there an acceptable range? I use rotella 15w-40. Thanks.
Old Feb 20, 2013 | 12:42 PM
Your operating idle is way to high, should normally be between 8 and 12, otherwise they look fine.
Old Feb 20, 2013 | 12:55 PM
MC04DII's Avatar
I drive a lot of frequent short distances so that may have something to do with it. The lowest I've ever seen was 13 or 14 after driving a good distance. Rave says 10 minimum, so I'm happy with mid teens (or at least I thought I was).
Old Feb 21, 2013 | 01:30 AM
Filter brand can also have an impact.
Old Feb 21, 2013 | 06:04 PM
94svt50's Avatar
your numbers are good. The higher idle psi might be a product of oil not quite to full temp.
Old Feb 21, 2013 | 06:27 PM
MC04DII's Avatar
Ha, yea I just came to that realization in the thread below this. I changed the oil and filter anyway and let it warm up longer and it's down to 12-17 at idle. All good.
MC04DII
Feb 23, 2013 09:25 AM
Chris-bob
Mar 15, 2012 07:02 AM
Spike555
ROAMING WITH FRIENDS
Mar 23, 2011 09:29 PM
meltdowndave
Jan 30, 2010 06:56 PM
mrcrptguy
Jun 7, 2009 06:01 AM
