Oil pump inner ring keeps pushing through when putting the front cover back on…
Old 07-29-2021 | 12:46 PM
Brandon318's Avatar
Default Oil pump inner ring keeps pushing through when putting the front cover back on…
Trying to get this stupid front cover back on, but the inner-most oil pump gear just keeps pushing right through and not staying with it’s fellow gear mates. Any advice for getting this back on?
Old 07-29-2021 | 01:14 PM
Brandon318's Avatar
Got it on… some lessons I learned I’ll share with future fellow strugglers.
1. Don’t PACK the Vaseline in like a lot of past posts prescribe. If it’s too packed, you can’t rotate the oil pump by hand. I scooped most of the Vaseline back out and used a lighter weight grease instead. That let me turn the oil pump gears WAY easier to align them. I use Park Tools Polylube 1000 (cycling/bike grease).
2. I got a short ladder and laid myself over the engine so I could see the oil pump inner gear moving toward the woodruff key. I had two fingers jammed through the front main seal, and was sort of able to move the gear here and there as needed to align as I eased it onto the crank. This also prevents the inner gear from pushing through like I was struggling with.
3. Sometimes a non-response from forum members forces ingenuity and perseverance haha.
Roont (02-28-2024)
Old 07-29-2021 | 01:19 PM
Best4x4's Avatar
I usually always mark the key way location on the front cover. Then when I'm putting the front cover on I verify it's still aligned and usually that's all it takes.
Old 07-29-2021 | 02:08 PM
mollusc's Avatar
You waited half an hour between your original post and saying that the forum hadn't responded.
Old 07-29-2021 | 06:10 PM
Brandon318's Avatar
Oh I know. Haha, I’m not griping or complaining, just making the overall point that it’s sometimes easy to use this forum as a crutch, rather than just sit with the problem for a moment and figure out a solution on my own.
The following 2 users liked this post by Brandon318:
cvhyatt (07-29-2021), jastutte (07-30-2021)
ttownthomas
04-30-2020 11:23 AM
mollusc
09-25-2018 09:54 AM
abran
05-21-2015 06:07 AM
boris_gti
10-12-2011 11:47 AM
Forrest
05-07-2011 10:12 AM
Quick Reply: Oil pump inner ring keeps pushing through when putting the front cover back on…
