Oil Pump Question
RE: Oil Pump Question
Did you do a search on here? There is a link to the TSB with the affected numbers. But the general consensis is to avoid '03's all together.
You can also write down the VIN to the trk that was offered to you and call three different LR dealers and ask them, you will get a different answer from each dealer. And they dont have to be in your area either, just ask the service adviser if he can look up your VIN and tell you if you are in the TSB or not.
If two of the three give you the same answer then you have your answer.
