Oil Pump Swap Problem
Old Sep 6, 2021 | 04:58 PM
robert.juric's Avatar
Default Oil Pump Swap Problem
I’m replacing my front cover and wanted to move the oil pump from my old cover to a replacement cover. When I removed the old cover the innermost oil pump gear was stuck on the crankshaft but I was able to slide it off.
So I swap everything good, put the innermost gear back with the set and line things up with the woodruff key. However when I went to put the cover back on, the innermost gear was pushed out the front and I can’t get it back in.
I didn’t think anything of it at the time until I had buttoned everything back up. Is it possible to slide it back in from the front or am I screwed?
Old Sep 6, 2021 | 07:12 PM
Brandon318's Avatar
Same thing happens to me every time. You can just slide it on with the front cover installed.
Old Sep 6, 2021 | 08:00 PM
I’m having a hell of a time with it. Spent at least 3 hours today and can’t get it lined up right
Old Sep 7, 2021 | 02:35 PM
Ok I think I got it. I used an inspection camera to make sure everything was lined up and spaced properly but it still wouldn't go in. So I finally got the spark I needed. I split apart the old oil pump inner gear and used it and a hammer to tapped it into place. It went in without much force. So I either got it, or completely f'd my oil pump.
ttownthomas
Apr 30, 2020 11:23 AM
abran
May 21, 2015 06:07 AM
boris_gti
Oct 12, 2011 11:47 AM
Forrest
May 7, 2011 10:12 AM
