Oil Separator
Old Aug 6, 2015 | 08:37 PM
Oasisplayer311's Avatar
Default Oil Separator
Anyone know what way the oil separator sits inside the valve cover? It has a flat end and a pointed end. And my valve cover has the cap on it.
2003 4.6l
Old Aug 7, 2015 | 12:17 AM
bosshogt's Avatar
It does not really matter which way you insert it. I had to trim mine slightly with a Dremel cut off wheel on the outer circles to make it slip inside the orifice. I also drilled out the the hole about a 16th bigger.
Old Aug 7, 2015 | 10:50 AM
As a form of maintenance, consider spraying carb clean thru the tube on to the separator to prevent any blockage. I have done this once a year for the last 13 or 14 year and never had to replace it.
Also consider cleaning the t/body at the same time for better crankcase flow.
Old Aug 8, 2015 | 12:00 AM
Bom2oo2's Avatar
I see you bought a new one, so go ahead and use it ,
But by suggestion of one of forum members, I bought a FRAM pcv valve $3-$4(part# FV237) (I know purelator has similar part but forgot #)
And fitted it, never have to worry about clogging again, one of best suggestions,!!
You can keep your existing tube in place (without seperated piece inside) and cut small section of existing hose & connect from top of existing tube to bottom of FRAM pcv valve & rest of hose from outlet of FRAM piece to intake , fits perfect, and don't worry about it clogging for years, it has a one way valve inside,
I have to thank the member that suggested the conversion,..
Old Jul 15, 2016 | 09:13 AM
redrover75's Avatar
Default Fram
I do not suppose you have a picture of this?
Old Jul 15, 2016 | 10:12 AM
Bom2oo2's Avatar
No sorry, I don't have a picture, but procedure is so simple you can't do it the wrong way,, just instal the new fram PCV valve after the existing tube that is connected to valve cover, (reminder,, remove noodle separator from inside tube first),,
austinlandroverbill
Aug 23, 2015 01:03 PM
dougn
Dec 29, 2012 09:56 AM
kae
Jan 24, 2010 10:38 AM
sheelhorse
Jun 22, 2009 11:38 PM
discoboy
Feb 11, 2009 01:42 PM
