Oil/ similar substance in Coolant
Old Jun 27, 2023 | 08:32 AM
  #21
arains44's Avatar
Originally Posted by Harvlr
On my D2 I had coolant in the oil. Because of the reputation of LR V8’s needing HG’s, I replaced them, but there was nothing wrong with them. The problem was a very bad timing cover gasket.
Gotcha. Yeah that makes sense. I really don’t think I have a HG problem, but I need to run a compression test to verify that.
Im confused on oil in the coolant. There’s not much evidence of that being a common rover V8 issue.
My oil is absolutely perfect. Even had it blackstone tested recently and it came back with no contamination whatsoever. Very puzzling.
Old Jun 27, 2023 | 02:18 PM
  #22
Harvlr's Avatar
But you’re still sure you have coolant in your oil? Could it be condensation? That would not be uncommon, especially in an engine that does frequent short trips.
Old Jun 27, 2023 | 06:42 PM
  #23
arains44's Avatar
I do not have coolant in the oil.
there is however, oil, in the coolant.
Oil is as clean as can be. No coolant contamination.
Old Jun 28, 2023 | 11:38 AM
  #24
Harvlr's Avatar
I’m not sure if oil can get in the coolant from the timing cover, but I know that coolant can get in the oil from it.
Old Jun 28, 2023 | 06:43 PM
  #25
arains44's Avatar
@Harvlr this is what my coolant reservoir looks like. No signs of coolant in the oil though.
Old Jun 29, 2023 | 11:35 AM
  #26
Harvlr's Avatar
It’s hard for me to tell from the photo, and I’m definitely not the expert here. If it’s only a few drops of oil I would keep driving it and monitoring it. Maybe Extinct will chime in here. He’s the coolant expert.
Jaden
Feb 17, 2022 06:15 PM
Gator996
Mar 1, 2017 06:56 AM
sayeedA
Feb 19, 2017 03:04 PM
Snafu / Disco Fries
Aug 30, 2011 08:29 AM
brianb883
Sep 21, 2009 12:33 PM
