Oil sump
Old Jan 4, 2015 | 06:13 PM
golgafrinch's Avatar
Default Oil sump
I just spent a better part of the day trying to get this thing (oil sump pan) off. I know I have all the nuts/bolts off (and a few more just for good measure) but I can't get it to budge. I can get it to wiggle a little up front but can't get it to go. Somebody must have used a lot of sealant or something.
Where is a good place to get ahold of this thing to pry it without breaking something?
Old Jan 4, 2015 | 06:27 PM
lordmorpheus's Avatar
I assume you also got the horizontal bolts holding the oil pan to the transmission bellhousing?
To avoid bending the mating surface of the pan, maybe take a rubber mallet and strike the corners of the pan?
Or pry against the triangular area of the rear of the pan (which extends out from the gasket area)?
Old Jan 5, 2015 | 02:44 AM
abran's Avatar
Did you get the two really deep sunk ones near the bell housing? You need an extension to reach them.
Old Jan 5, 2015 | 06:28 AM
coors's Avatar
Yeah, these are easy to miss. I did the first time I yanked the sump.
Old Jan 5, 2015 | 06:33 AM
drowssap's Avatar
yes, the 2 bolts that the RAVE does not take into account
Old Jan 5, 2015 | 12:28 PM
Thanks guys. I'll doublecheck when I get home. I definitely got the two forward facing ones and the 4 rear facing ones. And I think I remember getting the other two sunken ones. I'll report back later....
And yeah, it seems like I ended up with a few more than are mentioned in the RAVE. Haha.
Old Jan 5, 2015 | 12:48 PM
DustyLBottoms's Avatar
Yes, I did the same thing, turns out I missed 2 bolts.
Old Jan 5, 2015 | 10:33 PM
Well, it looks like I'm in good company. I saw those holes dozens of times and never realized there were bolts in there. Derp. Thanks RAVE.
But really, thanks you guys!
tito5590805
Apr 28, 2020 12:53 AM
powderhound
Apr 11, 2015 11:40 PM
zski128
Jan 12, 2015 03:01 PM
knightmetro
Jun 10, 2014 02:49 PM
mike111
Jun 2, 2014 08:58 AM
