which oil to use?
Old Feb 25, 2011 | 01:26 PM
yloDiscoII's Avatar
Originally Posted by Alex J
I'm running Amsoil 5w40 Euro. Amsoil says it can go a full year between changes but you need to get an oil analisis done around 4K miles of use to make sure everything is ok. Otherwise it may require more frequent changes. As long as the oil in my D2 tests ok I'm just going to change the filter a few times a year and keep the oil topped off.
I'd be interested to see if that Amsoil will hold up all year in a Disco engine....please post your results when you get them....
For the OP, I also run Rotella (either the full syn or the syn blend), my Disco seems to be a little noisier any time I've run Mobil 1 full syn.
Old Feb 28, 2011 | 11:07 PM
cobbcj7's Avatar
Originally Posted by unimoged
It depends on the ambient temperature, also if the engine has sludge or not and the oil pressure.
Sludged up engines would better with the thinner oils to prevent lifter noise.
In extremely cold temperatures 5W20 is what I have used to allow cold startup.
In CLT NC climate I use 5 W 30 in the winter and 5 W 40 rotella in the summer on the 04. On the others with the 4.0 L I use 15 W 40 and on the 2000 DII with sludge, I use 5w30 to keep the lifters quiet.
Well I am in Charlotte NC as well so I will go with what works for you.. Thanks alot...
Discovery_Scott
Oct 1, 2014 07:45 AM
Normd996
Mar 18, 2013 08:01 PM
buick215
Nov 20, 2010 12:49 PM
meltdowndave
Jun 23, 2008 07:14 PM
p38spares
May 14, 2007 03:55 PM
