Which oil to use
Old Mar 17, 2013 | 06:18 PM
Normd996's Avatar
Default Which oil to use
I recently picked up a 2003 Disco with 120k mostly dealer serviced they have been using all synthetic should i stay or switch to Shell Rotella T-6
Thanks
Old Mar 17, 2013 | 06:27 PM
dr. mordo's Avatar
Rotella. Cheap, common, full synthetic, and has additional detergents to help keep the engine internals clean.
Many people run T6 in every vehicle they own.
Old Mar 17, 2013 | 06:32 PM
Rotella, I use it in everything.
Change it every 5,000 miles, NAPA oil filters.
Old Mar 17, 2013 | 06:54 PM
Normd996's Avatar
Thanks will do its due for a change now
Old Mar 17, 2013 | 07:00 PM
120k you say?
Change it now, then again at 125k, then 130k, dont worry about the "100's", everytime there is a "0" or a "5" third from the left, change the oil.
Old Mar 17, 2013 | 08:25 PM
Madlands's Avatar
If you do change it every 5,000 miles make sure to check your oil atleast once a week. Mine won't lose any oil and then one week it may be a half a quart low. Checking only when you're topping it off during an oil change is pretty risky with the motors.
Old Mar 17, 2013 | 09:16 PM
kfx4001442's Avatar
I run Penzoil Platinum Full Synthetic 10W-40. Bosch Oil filters. I used to run FRAM filters untill I discovered how crappy they are made.
Old Mar 17, 2013 | 09:41 PM
Snafu / Disco Fries's Avatar
I run the T6 in warm weather and M1 0w40 in the winter. Here are the differences I see switching back and forth:
T6: Tends to cause or at least increase leaks. Nothing terrible but noticeable.
0W40: At idle or in traffic, engine runs 2-5 degrees higher. Not while driving though. Fuel economy is .5MPG higher while using it. Engine seems a touch more quiet.
While running M1, I have to add 1/2qt between changes. With T6 I have to add a qt.
Old Mar 18, 2013 | 01:49 PM
primussucks's Avatar
I was running Rotella for the last 18,000 miles, only issue is my truck sounded like a sewing machine. Rattling like crazy.
Check out this post I just made on another forum....
Texas Rovers: Forums / Discovery / Oil "Engine Guarantee"
Seems like it worth a shot.
Old Mar 18, 2013 | 08:01 PM
dgi 07's Avatar
Funny, noticed the temp thing as well. Been offroading in 100 degree heat running T6 and run cooler than in the with M1 0w40
Im using M1 0w40 as well in the winter time. M1 is quieter though, will say that.
Discovery_Scott
Oct 1, 2014 07:45 AM
cobbcj7
Feb 28, 2011 11:07 PM
buick215
Nov 20, 2010 12:49 PM
meltdowndave
Jun 23, 2008 07:14 PM
p38spares
May 14, 2007 03:55 PM
