OK, I just read my ABS codes and this is what I found...
Old Apr 19, 2009 | 10:18 AM
jrkstore43's Avatar
Default OK, I just read my ABS codes and this is what I found...
Well, there's an ABS Amigo is alive and well in Fort Worth, TX! Slick little device. Here is the information I got when I read/cleared the codes:
1.--Current Faults---->
Active Faults:
None
Logged Faults:
Front Right Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
OK guys....where do I start???
Thanks!
Old Apr 19, 2009 | 10:39 AM
brooksa's Avatar
I had same issue/codes a few months back and did an all corner brake job and have not seen the amigos since. I assume your ABS/TC isn't working? How are your brakes? Are they squeaking at all?
Old Apr 19, 2009 | 11:58 AM
jrkstore43's Avatar
No, it seems the ABS is not working (at least not prior to clearing the codes.) I was on wet streets last week and when you jam the brakes they lock up and do not pulsate at all. Yes, I have some squeaking in the brakes.
I have new EBC rotors and pads ready to go, but wanted to determine why I had the codes prior to installing the new pads and rotors.
Am I looking at a shuttle valve job here?
Old Apr 19, 2009 | 12:00 PM
Have your brakes been squeaking? Can you throw a panic stop and still feel the ABS pulsate thru your brake pedal? If so, clear the codes and see if they come back, if they do and your brakes are squeaking, that is your issue, I doubt the shuttle valve is a player here.
Old Apr 19, 2009 | 01:00 PM
brooksa's Avatar
I would put the new brakes on and see if that is the issue, was with mine....knock on wood lol...
Old Apr 19, 2009 | 06:13 PM
jrkstore43's Avatar
When I throw a panic stop on wet pavement, I get no pulsation, just locked and skidding wheels.
Drove about 40 miles today and the lights are still off, but I'm concerned the ABS is not working as it should...
Interestingly, the ABS Amigo cleared my "brake" light too.
Old Apr 19, 2009 | 07:41 PM
brooksa's Avatar
Try on some gravel, or get somewhere the TC should kick in, when mine was all cleared it took a little more to get the brakes to pulsate.
Old Apr 20, 2009 | 08:36 AM
jrkstore43's Avatar
You mention it taking "a little more" to get your ABS to kick in. Does clearing the codes actually cause parts of the system to begin working again? I had thought the codes were just a warning and didn't really affect the performance of the system. For example, you could have the 3 Amigos and still have an operating ABS system, right?
Old Apr 20, 2009 | 08:52 AM
brooksa's Avatar
Yes, my ABS/TC did still work when my 3 amigos were going off when I turned truck off but when I had the 3 plus the brake light and they stayed on after turning off then my ABS/TC would not work. I had the codes cleared and new rotors and pads on all 4 and have yet to see them again knock on wood.....and ABS/TC are working.
s10lowrider1994
Jan 25, 2012 04:29 AM
Jason_B
Feb 26, 2010 01:47 AM
kallgrer
Jan 14, 2010 08:54 AM
sloppyjoe
Jul 24, 2009 10:26 AM
aublec22
Jun 4, 2009 11:05 AM
