Okay fellas, need some quick advice...
Old Feb 26, 2008 | 10:18 AM
jdelp's Avatar
Default Okay fellas, need some quick advice...
My Disco's in the shop for a few items, I have LR extended warranty. They're fixing a valley pan gasket leak, bad window regulator, etc. I've also had a minor leak at both windsheild posts for some time when it rains pretty hard, but now it's happening all the time. I checked the sunroof drains, it's not that. I think it's the windsheild seal, but that isn't covered by warranty and they want $147 just topull the headliner and test it. Anyone tried some sealant at the corners of the windshield w/ success?
Old Feb 26, 2008 | 10:26 AM
okdiscoguy's Avatar
Default RE: Okay fellas, need some quick advice...
I have. I had a slight leak and toasted my fuse box. I put a bead of sealant all the way around the windhield at it has been fine for about 6 months now. I also put a small bead around the seal for the sunroof on my old Volvo and it held for 2 years just fine. Make sure and get the good black stuff made for windshields and you should be ok. Try it and see first, then you can dish out the cash later if it doesn't work...
Old Feb 26, 2008 | 11:02 AM
jdelp's Avatar
cool, I may actually try that. I'm a perfectionist though, so if I can't make it look OEM I may just replace the seal. Anyone ever had the windshield seal replaced and know the $$$?
Old Feb 26, 2008 | 01:40 PM
DuplinDisco's Avatar
This may be some help
https://landroverforums.com/m_51042/mpage_1/key_/tm.htm
dusty1
Feb 19, 2015 06:39 PM
Alex M.
Oct 7, 2009 06:47 PM
starcraft
Oct 1, 2008 09:55 PM
A03
Oct 19, 2006 07:09 PM
