OME shock blown after four months!
Old Dec 30, 2020 | 10:00 PM
jacobmstein's Avatar
Default OME shock blown after four months!
I looked under my car the other day and noticed this, my four-month-old OME shock covered in oil! I called Rovers North and they shipped out a replacement, no questions asked. I'm replacing the springs with 3" RoverTym springs so it's not much extra work, but still a bummer. I'm not sure if I'd buy another set of OME shocks. I'd probably go with Bilsteins.
Old Dec 31, 2020 | 08:34 AM
Dave03S's Avatar
We’re you running the original springs when you installed new shocks? No idea how many miles you have but new shocks on worn springs can do that. I did that to a set of Bilsteins.
BTW Bilsteins are not a better shock for these vehicles. Just more expensive. Unless you go the remote reservoir route... I can’t speak to those. I found they are stiff and don’t last long.
ive had Bilsteins, OME nitro chargers, and Terrafirma. FWIW I prefer the latter which oddly is the least expensive choice. Wasn’t expecting that.
Old Dec 31, 2020 | 09:16 AM
whowa004's Avatar
You can have Bilstein 7100s custom valved at no added cost essentially. $200/corner for remote resi is a pretty solid option imo. I have TF and fox shocks on my 2 right now and the adjustable TF are softer than the fox's however the vehicle with the fox has no bumpers or armor and is almost never loaded down which is a big factor there.
Old Dec 31, 2020 | 11:10 AM
No, the whole kit was installed at the same time.
Also, I'm referring to the longer travel Bilsteins.
Old Dec 31, 2020 | 01:18 PM
Richard Gallant's Avatar
@jacobmstein Could be you just got a faulty unit it does happen, I have run and am currently OME and have never had a failure like that. I know this is unlikely but are you using the wrongs shocks, too light for your load
Old Dec 31, 2020 | 03:24 PM
The only added weight on the front currently is a bull bar. I have MD OME springs in the front which are rated correctly according to Rovers North. As for the shock, I believe it is the HD variant, at least that is how it was described when I bought it.
edit: after looking into it, I think the Nitrocharger Sport Shock sold with all kits is meant to be HD.
Old Dec 31, 2020 | 04:05 PM
@jacobmstein Thats for reply I figure you had it setup right but never hurts to check, I think you just had bad luck
Old Dec 31, 2020 | 04:11 PM
redwhitekat's Avatar
Thought OME was the best
Old Dec 31, 2020 | 08:17 PM
They are very good but like everyone else they do have failures, the only downside is your truck tends to ride harder with OME stuff
LRlax11
May 3, 2021 12:33 PM
Tomzsix
Oct 1, 2017 11:17 AM
KingKoopa
Jun 28, 2017 11:08 PM
swank1975
Jun 6, 2011 08:02 AM
rwarren92
Jun 24, 2008 08:06 AM
