OME Springs/Shocks
Old Mar 26, 2010 | 11:50 AM
bantham1's Avatar
Default OME Springs/Shocks
I have a 98 Disco with 85k miles. The suspension seems pretty soft and I am thinking of putting new shocks and or springs on. Do I need to change the springs or just shocks to firm the suspension? If so, which OME springs/shocks would be good for a stock tire size or a slightly larger tire? I have seen some info that a 3 inch lift will occur with some OME springs. I may add a larger tire but do not want a huge fender gap with the setup.
Old Mar 26, 2010 | 11:55 AM
Here is a link for you to visit, it will describe the different coils OME makes for your truck. I would use the mediums front and rear along with a new steering stabilizer and the OME H.D. shocks. http://www.expeditionexchange.com/ome/indexsprings.php
Not knowing where you live, here are 2 sites for good prices, Lucky 8 or LRRF.COM
If you have any questions get back to me.
Old Mar 26, 2010 | 12:04 PM
bantham1's Avatar
What size tire would you recommend with the medium kit?
Old Mar 26, 2010 | 01:25 PM
What size tires do you have now. A small lift doesn't mean you have to up-size the tires, unless you just want to.
Old Mar 26, 2010 | 02:17 PM
bantham1's Avatar
I will have to look at the tire size. I believe they are the stock size. I just do not want a wide fender gap and a larger tire would fill the gap. I don't want to go too big though and have rubbing issues.
Old Mar 26, 2010 | 03:12 PM
There were a number of stock sizes, most likely a set of 245/75/16's is what you should look towards.
lipadj46
Aug 4, 2009 06:06 AM
andrewmcoffin
Mar 24, 2008 10:29 PM
adowgiert
Dec 10, 2007 08:15 PM
bklahl
Aug 15, 2007 08:19 AM
newBrover
Mar 24, 2007 07:11 PM
