One Man Brake Bleed
One Man Brake Bleed
So I went to bleed the brakes and needed the tool with the check valve in the end of the hose and could not find it in stores. So I just used an old vacuum hose and a container with brake fluid in it to prevent air from coming back up the hose into the system. I did not want to pull my wife out of the house so I improvised. This seemed to work. I have drove it a couple times with no issues. And for those debating not bleeding their brakes( I debated never doing it) I had a good amount of black particles in the fluid that came out along with some nice reddish orange fluid. Anyways I used this broom pole with a towel to protect the seat and the seat adjustments to hold the brake pedal down. Sounds ghetto but it worked pretty well.
A wife will not do automotive repair without a good strong argument.
She will say - you are driving an old POS. Get a new car.
However, in the 12 year span - the wheels were cleaned before entering the car wash.
And, without brake dust cleaner solution.
And I did not clean them.
Guess who? It was a miracle.
I used this to bleed my brakes by myself, it worked great.
Although I had to duct tape it to a piece of metal hanger to get the desired shape so the end would stick out over the pan, and not the inside of the rim
Amazon.com: KD Tools (KDT2538) 1 Man Operation Brake Bleeder: Automotive
I too use this. Works great. Not sure how many uses you'll get out of it - one of mine was dead the 2nd time I went to use it.
Dave
Evan5291
07-27-2017 10:04 PM
bosshogt
09-16-2011 12:46 PM
flyingalexf68
05-09-2006 01:51 PM
