One Man Brake Bleed
Old Oct 3, 2012 | 06:31 AM
bigcraigman's Avatar
Default One Man Brake Bleed
So I went to bleed the brakes and needed the tool with the check valve in the end of the hose and could not find it in stores. So I just used an old vacuum hose and a container with brake fluid in it to prevent air from coming back up the hose into the system. I did not want to pull my wife out of the house so I improvised. This seemed to work. I have drove it a couple times with no issues. And for those debating not bleeding their brakes( I debated never doing it) I had a good amount of black particles in the fluid that came out along with some nice reddish orange fluid. Anyways I used this broom pole with a towel to protect the seat and the seat adjustments to hold the brake pedal down. Sounds ghetto but it worked pretty well.
Old Oct 3, 2012 | 07:31 AM
Antmen's Avatar
Love it! That's great!
I also used the jar with some fresh fluid in it and submerged the hose end into it. But I gotta try that broom trick, because it got pretty heated when my wife and I were yelling back and forth.
-Anthony
Old Oct 3, 2012 | 07:15 PM
jfall's Avatar
A wife will not do automotive repair without a good strong argument.
She will say - you are driving an old POS. Get a new car.
However, in the 12 year span - the wheels were cleaned before entering the car wash.
And, without brake dust cleaner solution.
And I did not clean them.
Guess who? It was a miracle.
Old Jul 30, 2013 | 02:17 PM
dusty1's Avatar
i know this is an old thread, but I was trying to see if anyone had ever tried the one person bleed check valves or even that wonky looking pump thing as a solo solution to brake bleeding
Old Jul 30, 2013 | 02:32 PM
caymandrew's Avatar
I used this to bleed my brakes by myself, it worked great.
Amazon.com: KD Tools (KDT2538) 1 Man Operation Brake Bleeder: Automotive Amazon.com: KD Tools (KDT2538) 1 Man Operation Brake Bleeder: Automotive
Although I had to duct tape it to a piece of metal hanger to get the desired shape so the end would stick out over the pan, and not the inside of the rim
Old Jul 30, 2013 | 03:01 PM
dusty1's Avatar
Post
great, thanks. i will go that route. was not sure if it worked.
Old Jul 30, 2013 | 06:19 PM
jfall's Avatar
I like this old thread.
Thanks bigcraigman for posting it.
A bottle and a hose is just fine.
Simple is best.
Old Jul 31, 2013 | 06:40 AM
drowssap's Avatar
you can also buy speed bleeder these days, they have a spring loaded check ball.
you loosen the bleeder and pump away, when you tight the bleeder the ball bottoms out closing it.
Old Jul 31, 2013 | 07:32 AM
Ghaniba's Avatar
I too use this. Works great. Not sure how many uses you'll get out of it - one of mine was dead the 2nd time I went to use it.
Dave
Evan5291
Jul 27, 2017 10:04 PM
bullcrew
Jan 22, 2012 10:39 PM
JavaDiscoII
May 29, 2010 04:33 PM
flyingalexf68
May 9, 2006 01:51 PM
