OOhhhhh god!!! i think i ruined it!
so im sitting at sonics tonight and im messing with the RPMS to see if the idle was setting right. (Just put in a new IAC valve)
So the person leaves the next window so i without paying attention slam the car into Drive and the LR just peels right the **** out.
Now my shifter is just...Destoyed, A square part is around it and it gets stuck when i shift into park. or 1st.
Please tell me i just need to put that square part back in the right place...PLEASE DONT SAY I RUINED MY TRANNY!
Um guys, I need help to find out how to fix my shifter, The little square piece with the ball was sticking up and i got that back down...But is it supposed to set somewhere below? and now the little plastic cover is ripped...Please tell me how to take this apart and replace what i need...
you can get the tape on http://www.roverparts.com/Parts/RTC6683.cfm I think.....It will be for a RRC. I got one for mine. There is a cover on the top of your shifter the prys out. You can remove the clip for the shifter button under there, then slide the handle off. Then you can pull out the ball thingy. That square on the ball thingy is supposed to slide in the groove, attached to the shift tape (that is now torn). With the tape torn, it will hhave to be replaced. To get to it properly, you will have to remove the entire center console. Lots of fun on that one.... Check RAVE for that removal.
