Oops - broken air filter housing clamp (pic)
Old Apr 26, 2010 | 11:42 AM
Antmen's Avatar
Default Oops - broken air filter housing clamp (pic)
I went to check the air filter on my new-to-me Disco and the clamp on the right (see pic - near throttle body intake hose - i think that's what it's called) didn't fully open as it was blocked by a radiator hose (see pic.) So, I decided to pull up in hopes of clearing the hose. 'Not a good idea! It cracked the molded plastic hinge on the cover. Oops.
Other than that, all the other clamps seem pretty tight and the hose sits at least 1/2" into it, so I don't think it will loose any significant suction, so I'm not worried much, but I will replace the air filter cover sooner rather than later.
I thought my BMW 325i was tight under the hood. The DII seems even more so.
Old Apr 26, 2010 | 11:47 AM
Shane83's Avatar
Mine is the same exact way... Broken in the same exact spot... I bought it that way though... It doesn't throw any codes or anything...
Regards,
Old Apr 26, 2010 | 11:49 AM
Antmen's Avatar
Yeah, I checked and no codes. My concern - other of losing intake suction - is dirt getting in through there as that would be post-filter, so that's why I'm thinking of replacing it "sooner rather later."
Old Apr 26, 2010 | 07:50 PM
Willie00d2's Avatar
I had mine break like that too. I put a 1" c-clamp on it. It's been on there for 100,000 miles now. Not really the best way to fix it but it works.
http://www.flickr.com/photos/roverd2/4556508202/
Willie
Old Apr 26, 2010 | 08:21 PM
CopperMtnGuy's Avatar
Just fill it in. JMO. If it looks as small as it does in the pic.
Old Apr 26, 2010 | 09:04 PM
willrok13's Avatar
Honestly, I have yet to see a Disco without that part broken. I tried to epoxy it on my last Rover ('03) but surprisingly it wouldn't hold. I would probably safety wire that clamp, can't imagine where it would end up if it came off!!!
Old Apr 26, 2010 | 09:41 PM
Disco C's Avatar
Mines broken too!
Old Jun 16, 2010 | 01:36 PM
Kswin's Avatar
Default Air Box Cover
Yeah mine broke completely off, been looking for cover for awhile, can find 02 but not 03-04.
Old Jun 16, 2010 | 02:21 PM
vandev's Avatar
Default engineering...
another engineering marvel.....nothing like metal with pressure pulling on plastic in a engine comparment that is actualy too hot to smoke a pig...Fu&cking idiots the bunch... mines broken too but buying another faulty part that will break again is a sign i submit to there bullsh&^t..
FM... FT....
Old Jun 16, 2010 | 02:52 PM
Bundu's Avatar
Banned
Yip, my '03 as well, the PO practically destroyed the whole cover and air intake hose. I had to replace everything and got the air cleaner box and hose for under $100 on eBay. They are pretty scarce in a whole state though. The new parts cleared my error codes though, so I'm happy with that.
nehi1429
May 21, 2015 09:28 PM
erictj
Sep 2, 2014 03:25 PM
70gsrick
Mar 16, 2012 12:06 PM
jbarr89
Feb 14, 2011 08:18 PM
tsuami1
Sep 21, 2009 02:10 PM
