Option b woes
So I decided to fix the three lights by doing option b. I found that one of the three bolts wasn't there and one of the Allen heads was stripped out I pulled the whole abs unit out and my flare wrench set did not have an 11 so I winged it and of coarse rounded off one of the brake line connectors.
What I found was that the black wabco plate had been badly replaced in the past. One bolt had the head drilled off and one was in fact stripped. I have a spare abs unit so I put the option b plate on it and will drop it in. When I pulled that spare abs unit a year ago I taped it up to keep stuff out of the holes. Was wondering if I should flush the unit out anyway. Any thoughts?
Received 1,188 Likes
on
Yep, the joys of being a mechanic and when the conversation starts with... "yeah, l started to repair it...but ran into problems...so, l brought it to you".
Great, thanks...appreciate you thinking of me...after it's all messed up by your harbor freight tools and lack of mechanical skills.
