Option b woes
Old Apr 14, 2019 | 07:03 PM
zuke's Avatar
Default Option b woes
So I decided to fix the three lights by doing option b. I found that one of the three bolts wasn't there and one of the Allen heads was stripped out I pulled the whole abs unit out and my flare wrench set did not have an 11 so I winged it and of coarse rounded off one of the brake line connectors.
What I found was that the black wabco plate had been badly replaced in the past. One bolt had the head drilled off and one was in fact stripped. I have a spare abs unit so I put the option b plate on it and will drop it in. When I pulled that spare abs unit a year ago I taped it up to keep stuff out of the holes. Was wondering if I should flush the unit out anyway. Any thoughts?
Old Apr 14, 2019 | 10:01 PM
Best4x4's Avatar
Dang that sucks! it won’t hurt to purge out the unit.
Old Apr 14, 2019 | 10:39 PM
FlyingZebra34's Avatar
The woes of fixing other people's "fixes". The bane of my existence. Sucks to hear.
Also yes Purge the unit. Old brake fluid becomes corrosive over time when is absorbs moisture.
Old Apr 15, 2019 | 04:32 AM
shanechevelle's Avatar
Agree
Old Apr 15, 2019 | 05:58 AM
The Deputy's Avatar
Yep, the joys of being a mechanic and when the conversation starts with... "yeah, l started to repair it...but ran into problems...so, l brought it to you".
Great, thanks...appreciate you thinking of me...after it's all messed up by your harbor freight tools and lack of mechanical skills.
Old Mate
Jun 9, 2017 02:42 PM
mmaesner
Apr 8, 2015 02:55 PM
Derry Quinn
Freelander
Sep 5, 2012 02:17 AM
boris_gti
Jan 28, 2012 05:43 PM
coors
Nov 14, 2011 10:20 PM
